Problem with custom bitmap fonts
Hi, I am consistently having a problem every time I finish a watchface and upload it to google play.
For example, I create a clock with the expression [HOUR_1_12_Z]. Next I select the bitmap font type as shown below.
When I test the design everything works correctly, when the expression is 01, it returns the image with the zero shaded. However, when I upload this design to Google Play and download it, this does not happen, the 0 is always illuminated. Therefore, I think that it does not respond to the default expression 01 (for example).
If someone could help me I would be very grateful, thank you.
You need to reset every number (0-10) and add another batch of custom (10-24).
Thanks for the help!
