Progress Bars
There are google watch, and samsung galaxy watches which does not have the issues you facing…wfs dont support apple (not apple fan either)
Yes there are… BUT , they don’t have anything near the battery life.
Nether one are using Snapdragon W5+ Gen1
Ok… Made some progress based on r.liechty_SDRSamsung Developer suggestion about using “TAGS”
Really cool because my TicWatch can be set to REAL TIME MONITORING and give a new reading every minute. Something I have not read that anybody but Apple can make a watch do.
BUT. There is ALWAYS a BUT isn’t there.
There isn’t a tag for the Blood O2. I am going to fire off a SUPPORT REQUEST to TicWatch/Mobvoi and ask for the TAG.
Because if you are purely designing for your own use then customizing your own progress bar when possible is the best method.
Also many complication types and even parts of the complications are optional.
Ron
Samsung Developer Relations
I wonder if I can “easter egg” the tag?
Sorry no o2 tag atm . No work around yet maybe text only.
Have u tried third party complication? Wonder if its the default apps issue or watch os issue.
Try amoledwatchfaces complications (if this works good ) if not then only work arounds are the way to go abait limitations
Sorry though amoledwatchfaces doesnt seem to have a o2 complication either
Looked it up. Doesn’t support Blood O2…
Does a “TAG” have to be in the “TAG LIST” to be used?
Here the documentation
Anyway try other range complication from the suit first e.g battery see if it fixes the thickness of progress bar.
So u know where the issue is.
This
just gave me a lot of additional questions that I will have to start other topics on.
BUT
I didn’t see anything in it that bears directly on the issue of getting a useful Progress bar for Blood O2
Like i said no 02 tag, i tagged @r.liechty_SDR to answer u why dont have such tag.
Btw the O2 complication does not auto update its updated when u tap on it to view the app. So u better of just creating a shortcut to the app on the watch to monitor your o2
Create a small image type complication. And put it as shortcut
It does autoupdate on my TicWatch. Because i have tricked it by setting my sleep time to run from 12 noon to 11 am, then i turned on the BO2 continuous monitor which only works during sleep time. No. It isn’t perfect, but since i am old and spend more time than i like relatively inactive, it gets a reading fairley regularly.
Ok, Even battery results in narrow progress bar as editable complication.
Doing the non-complication bar with a tag works.
U mean using third party app…? Seem its the watch randering of complication has issues
What do you mean by “third party app”??
I tend to agree that the watch simply will not properly render a progress bar as an editable complication.
I did get the TEXY ONLY EDITABLE complication to work in my original Topic.
The one i suggested from amoledwatchfaces,
“The one i suggested from amoledwatchfaces,”
They do not have anything for Blood O2…
Hi, i said try amoledwatchfaces watch battery complication… to eliminate weather its watch default complication issue or the os…
Not your watch battery complication
Screenshot_20240201_093838_sysui
Not available for my TicWatch Pro 5.
