oh ok, no choice cannot test
Having a bar for the HR is the most important thing for me.
I can get by with BO2 in a large text i think.
Wil work on that and hope Mobvoi/TicWatch offers a solution other than their subscription design tool.
I told you how to do that, in WFS click on Component and add the progress bar, you can make it a bar or a circle type set the colors etc.
There should be a circle health complication that when pressed opens the SPO2 app on your watch.
Ron
Samsung Developer Relations
TicWatch Pro 5 is definitely supported. Your screenshot is not even showing your TicWatch Pro 5 so issue must be on your end. Maybe you have different Google account on your Pro 5?
Tomas
Humnn… Thanks for pointing that out. Not sure how it happened but watch got signed out of the google account.
Ok. I have the Complications Suite on the Watch…
What do I do with it?
It doesn’t appear to offer a PROGRESS bar of any kind.
Select the phone battery complication like u usually do, as shown as my screenshot.
?? This isn’t something I EVER do…
How do you customise your complications? U click customise then go to complication tab on your phone/watch and select…? Or u use default complication on wfs?
By the way i think try time instead of batt…for batt its another app from same developer
In wfs used editable complications
Touch and hold your watch face to go customization mode.
Which watch face?
The one I am trying to make?
Also…
Somehow my watch keeps getting logged out of my account.
I think I need to get that straightened out first.
Yes the watch face u installed on the watch…the one u load as the face u using
OK, I got the watch signed back into it’s account.
All… Let’s reset and start over so I can get clarity.
I will start a new face and post the screen shots and code to follow.
Ok. So?? Do I need to make the TIME on the watch face I design EDITABLE?
I mean on wfs instead of using default provider set it to empty. And select editable…
Then your complications slot u can choose what complication u want to use on the watch
Wear 3.x is pretty quick to close the WiFi for battery saving. I think that is what happens. the trick is to have WiFi continuous when charging I think it is an ADB setting.
Ron
To everyone giving me a boost on this, thanks.
Sorry I am sometimes a bit slow getting back with answers or results.
When the sun shines I have to spend my day working outside on my property and sometimes I just don’t have the energy to sit down and wade through the suggestions and try them all out.
Supposed to rain tomorrow so I might get a whole day to play inside.
Again, thanks for your patience.
Seem better then your previous one…so i think it the watch default complication issue…only way to go is used non-factory complication
You edited the wrong layout by the way. Edit all the available layouts on the right of wfs as in click on each layout then djust thickness of all its progress bar.
This is because complication will choose from anyone of those by default… the layout selection in wfs is for u to preview all enabled layouts and edit them
May i know how you choose B02 as complication for your watch…because i told u to use time and u told u dont know how…but if u could select B02 then steps should be same for any complication…and i dont remember u can selected that in wfs
I did you TIME as per your instruction.
17:39 24h right in the middle of the watch screen shot HEADING >> WHAT I GOT.
Now I have to say, I have no idea how the TIME would be displayed in a progress bar. Looks like the watch said >>> U and defaulted to text.
