Hello,
I have the QE75QN85 TV and I am making an application for my TV.
The problem is that I can’t do remote Device and the same error message is always appearing.
I activated Developer mode using the key “12345” and reset the TV.
I’ve also factory reset my TV and done the same steps to activate Developer mode but unfortunately it still doesn’t work.
Both my TV and my mac are on the same network and both are connected to Wifi.
When I activate developer mode and try to change the Host PC IP, the TV does not pop up the keyboard to enter the ip.
This behavior is very strange, because as soon as I activate the Developer mode the TV appears in the Remote Device Manager.
Can anyone help me try to figure out what I’m doing wrong?
I can’t tell from the message what the error is.
TV Model: QE75QN85BATXXC
Software Version: T-PTMDEUC-1304.1, BT-S
Status Code: 40301_AC1AE3_IL1
Thank you so much.
