SC_PER Tag not work correct
I use the [SC_PER] tag for a progress bar.
When I change the step goal from 2000 to 5000 on the watch, the progress bar doesn’t update, it still uses the project settings for Health.
What can I do to use the changed clock setting without create a new watch face?
Ciao
Stefan
Hello, I think there is no option in WFS to make it any better than to set one value before building the watchface, then set diferent one and build another version. to change goal you would have to switch between those watch faces.
