I have created a custom seconds dial I want to use sweep effect in CWW Im finding this is greyed out and fixed to use CW is there any workaround to do rotation of image in sweep mode in CWW direction.
What is annoying is it works using both Normal and Tension mode and you can change no problem to CWW direction.
Hi, yes there is a workaround. instead of using rotation properties for a hand, just insert it as image and use expression to describe the rotation with negative angle like this:
