Hello to everyone,
i realized that suddenly my watch faces get huge performance issues when the “animated system icons” shows up on the watch (for example night mode, music). You are able to force it when you switch into the night mode. The moon icon appears on bottom of the watch and suddenly everything gets a huuuge performance drop. Especially when you use “Tension” as movement effect for rotating objects.
This is really a bad bad thing. So is here anyone else with the same problems?
I am able to reduce this issues when i turn every rotating effect to normal. But sure this is not a long term resolution. So can anyone help me here?
Matze - styles4you
