Tap changes
Hello everyone.
I made a group of text blocks and a group of icons. I want a group of text to change to a group of icons and vice versa when tapping on a certain area. How to do it?
I’ve only ever seen this done on one watch face. I bought the face just to try to understand how he did it, but I believe the face was built in Android Studio, and not WFS.
I haven’t been able to accomplish this in WFS yet, but maybe someone here is smarter than me and knows a trick to it.
Here’s the face if you’re interested in checking it out.
You could make two images one with the Icons the other with the Text use an image swap tap . The images would have to end at the split line . The tanp area will be the size of the Image .
Like @russellcresser said above. And you can even make up to 10 variants of what will be shown in that place…
How do you get a “tap” on the screen to make a change? I could never find an Action that made this possible.
Apparently I haven’t looked at Tap → Action in a while (Since 1.7.13). You can swap media with a tap now.
I am away right now . I have no WFS . I think Peter might point you to the Switch on the Image Layer . I bet he is on it as we speak .
I think we answered this somewhere indirectly, but I cant find good topic right now, to not confuse you with unrelated stuff.
I rather made this quick anime. I think it is super easy once you know where to search :slight_smile:
Animation
this idea also came to my mind, but the problem is that different color schemes are associated with different text fields and icons.
You can apply theme colors to swapping images too, if you do not mind icons following the same color as text.
Now I have to come up with a design that can use this!!!
