Theme Issues - Can't fix with GTS
Hello designers,
I’m posting here (first time) to share information, similar issues and maybe some solution/suggestion from you guys.
And if there is a way to fix these problems, I will be immensely grateful to you.
So, I submitted a theme which was rejected due to the errors identified below (Issue 1 and 2).
As my themes are predominantly dark at the moment, this can prove to be a big difficulty, even though several previous dark themes have been approved with these 2 problems.
I also submitted a ticket to the Customer Support team, providing shots of the problem on the phone, screenshots of the tool setting, a few screenshots comparing themes applied, the tool version, the APK and STP files, and for now I’m waiting for their feedback.
** I am aware there is an active thread created by Alexander, compiling all the problems already detected during 2021 validation. If it is of interest or it’s convenient, I can include the info in his thread.
** As soon as there is more information and feedback from the Customer Support team, I’ll include it here.
Issue 01
Android OS: Android R 11.0
Detected Device: SM-G996B / G996BXXU3AUIE
Issue Step: Clock - Alarm - Alarm sound - Check sound icon
Issue Descritpion: Visibility of button, but it’s default Black.
Conclusion: Issue can’t fix with GTS.
Solution: Should be fixed via App Update by Developers
Issue 02
Issue Step: Apps screen - Folder (Samsung/ Google/ Microsoft) - “+” - Check the Indicator bar
Issue Description: the indicator bar turns dark.
Note: The light mode is active on the icon and text color on status area color (Common / Background menu). So I guess that this issue can’t fix with GTS.
Finally, if you have comments or suggestions, this is the place.
And I wanted to say that this is pretty frustrating (you guys get it, right?!) as the theme in question is a Halloween theme that I was incredibly excited to post after working so hard on it.
Hi,
About Issue 1 , I guess it can be fixed there
Themes Studio > Common > Controls > Buttons > Text color (Dark)
About Issue 2 it’s a Issue in the Finder App, so no way to fix it. I suggest to resubmit the Theme and add the Link to this Thread for Review Team
Hello and thanks for the reply Alexander!
About the Issue 1, at first I thought I could have wronged the configuration and added a dark color for the button text, but no. The text color (Dark) is light #FFFAF2.
I did some tests with other themes, applied different color scheme to the theme in question (the poor theme already has several versions… even restarted the layout from scratch), I also applied themes from other designers, then tested at least 3 themes I have where I don’t use black #000000 at all (or dark colors with a value close to it): the sound button remains black.
That’s why I believe it’s not something that can be changed or fixed in GTS, but it’s a bug that should be fixed.
I’ll do as you suggested: submit the theme again attaching the link to this thread to the Review Team.
Anyway, thanks! And hope to have some positive news on this issue soon.
For future reference I would suggest to report theme issues that are unfixable by designers through this page instead: https://developer.samsung.com/dashboard/partner
