work for me, macbook air m1, thank you
Hi guys,
It is clear by now how to fix this issue by using the right jdk
version bundled with the installer. I have published the instructions for other developers to quickly find it: Install Tizen Studio on Apple M1.
I hope you will find it helpful. Let me know if you have any suggestions on how to improve it (make it more clear).
Have a good one!
Thank you for useful information. That can make me use the information to work in order to continue working effectively. Thank you.
Worked for me as well, thank you!
Also, note that the directory was <$USER>/.package-manager
Hey thank you so much, your steps are gold !
I was able to install on M1, but i’m not able to get run the tv emulator, i get to install HAXM.
I don’t know what i should do !
Hi, I’m also not able to run the TV emulator on my M1 (Apple Silicon) Mac. Is it not supported on this architecture ?
Since no one responded, I would suggest you look for an answer in the FAQ-Q/A under the most appropriate topic on the Smart TV Seller Office site If you don’t find a solution there then sign in and open a Smart TV Seller Support Request . They can help you better there.
Ron
Samsung Developer Relations
@manuja.desilva
Hi,
Now, Tizen Emulator is not working on Apple M1/M2.
