I am able to run Tizen Studio (TS) 4.1 in Mac OS Big Sur 11.4.
Initial Problem in installing TS 4.1 -
- on clicking installer, it’s asking for lots of Mac access for each package which is really frustrating
- After allowing all packages, the Agreement page is frozen, and no way to move forward.
Solution -
Instead of installing Tizen Studio 4.1 with IDE installer, I choose Tizen Studio 4.1 with CLI(command line interface) installer.
You can follow the installation command from here
1 - Run the .bin file in the terminal where it is downloaded and follow the instructions.
./web-cli_Tizen_Studio_4.1_macos-64.bin --accept-license
2 - Once above command is successful, you can see Tizen Studio folder in Home Directory.
3 - Now go to directory $HOME/tizen-studio/package-manager in terminal
Install Native IDE
./package-manager-cli.bin install --accept-license --no-java-check NativeIDE
4 - Download packages that you need.
./package-manager-cli.bin show-pkgs
I was interested in wearable devices
./package-manager-cli.bin install --accept-license --no-java-check WEARABLE-6.0 WEARABLE-6.0-Emulator WEARABLE-6.0-WebAppDevelopment
5 - Boom, you can see TizenStudio launch icon, double click and click on template
Select the application profile
Mobile, wearable, TV
If the profile is not available, follow point 4.
Note: I also set up JAVA_HOME with version java 15.01 but I am not sure it has anything to do with it.
