Watchface and WatchFace sub
Is it possible to make a “push button” for the master watchface, and that button another sub watchface that should show a lot of other “Press buttons”
It depends on how complicated your watch face is. you can set the background as a button and change image to one that just has arrows &text showing where the buttons are and what action they have. Watch hands would need to be less than 360 and it would only work on the rim. For digital clocks it would work anywhere this isn’t another button action. It would only show what the background shows so the information would need to be placed correctly.
So it is possible, not sure if it is practical.
Ron
Samsung Developer Program
In GWS, If you do not mind that the first watchface would not be customizable (background as button image, changeable hands and so on), you can make your watchface, then put a transparent image 360x360 above it and set it as button. It would change to an image that you prepare with all the buttons representations. When touched again it would become transparent again. Over this image put number of smaller transparent images over the spots with button representations and set them as buttons to open desired apps. remember to leave some uncovered area to be able to touch the “main” button. The smaller transparent images would remain active even when the main was not touched and still transparent. In version 1.6.2 you could keep some elements below still customizable despite being covered with other full-size buttons.
Once I have made the main watch face with a large button, how should the link to Wacth face 2 be set up?
Please attach picture with workflow.
You select change image then below click on the + and add an image. In this case is the invisible one you made in Photoshop. You can’t just have opacity at zero. There is a .png that comes with Samsung that shows an image with nothing in part of it 12…png you could use that to get an idea of howit would work
Edit - I should have waited for Peter :slight_smile:
Ron
There is actually no link, just the set as button and change image action, you already know. It is just transparent at start and waiting for touch to show the 1st image for change. Then when touched, it displays the button drawn positions, but the actual buttons are another smaller transparent images above it. Maybe the screen shot makes it more understandable.
