I am trying to use custom icons for a weather display on a watch face I am building. I plugged in all of the string values according to Weather Conditions - OpenWeatherMap, but some of them are still not showing up.
For example, last night was snowy and the icon was showing up fine. But this morning it is cloudy, and there is no cloud icon showing up.
I have checked it by using the bitmap font mapping against the Display Type as Number. It works fine in my case. Can you please check if your mapping to string in the bitmap font setting is right?
Therefore, if your mapping is okay and you can’t find the workaround, please submit a support request to Samsung Developer Support.
