I had started a watch face project with the older version of WFS 1.0.3 and I opened it using the latest version 1.0.12 and when I try to build it, build progress goes to 100% immediately and I get an empty warning box and nothing happens after that. The warning box is empty so I don’t know what the warning is. Run on Device is working fine though.
We need the log from PC right after this issue is happened to investigate the issue.
Path of the log:
Window : C:\Users{User}\AppData\Roaming\watchfacestudio\dump\main
macOS : /Users/User Name/Library/Application Support/watchfacestudio/dump/main
Please report this issue as a bug from Support>Developer Support and share the log while submitting the bug report. Please don’t share the log in this forum.
I deleted the watch face studio app and removed the watchfacestudio directory from /Users/<User_Name>/Library/Application Support/ and reinstalled the app. The same issue is happening with the new installation as well.
It seems that there is a possibility that the wrong value will be included in the location path due to this feature. “Provide used build information in Build information. - Supported from 1.0.11.”
Could you check if the issue remains after re-setting the “Location” in Build dialog?
The default path is {workspace}\build{project name}.
1st screenshot
i dont know whats wrong but i cannot run a recently uploaded watchface. i open the wfs and try to run it and it says build failed.
2nd screenshot
then i try to use the build option and it starts and then says font file not found. i have tried changing workspace and doing clean install
has started to happen lot now on different wfs projects which i never had any issues previously. its really disturbing to remake already build and completed projects, just because you edited in 1.0.12.
I have checked the dump log. it says that no fonts are present in the res folder.also includes all bitmap fonts. im going to try adding all fonts again . i have inspected the wfs with winrar and the fonts folder inside is empty .there are no fonts inside.
I have managed to restore back and make the build work.
But i had to literally swap every image again because the log indicated after font correction about all images also missing
I had to add all bitmap font images as well. That means i had to literally add everything again .AT least formatting and text tags worked didnt have to do them again.
