the same happens to me. I can’t sync the watch 4 to samsung studio faces
Please read the thread many have gave their solutions already
You have to use WiFi for Debugging the Bluetooth is considered a security risk
Are you using Watch Face Studio or trying to use the old Galaxy Watch Studio (it is the wrong tool).
Ron
Samsung Developer Relations
I am using Watch Face Studio
Should I debug ADB and wireless networks?
I do it but it can’t find the watch 4
Hi what version of studio u using
Hi maybe u will find a solution in this thread instead
You can follow the steps below to connect with WFS and Wear OS4 devices:
- Connected the watch and PC on the same Wi-Fi network
- Turned on the Developer Options on watch (Settings->About watch->Software->Software version)
- Tap 5 times on software version. After tapping 5 times on software version, show a text that development mode is on
Turned on ADB debugging (Settings> Developer options> ADB debugging)
Turned on Wireless debugging (Settings> Developer options> Wireless debugging)
Get the IP port from watch and put it on the IP port field on the WFS. Check the image below:
Press on the “Pair new device” below the IP address and port option
You will get a new pop up. Get the pairing code and pairing port from the pop up and put it on the WFS. Check the image below:
If you face all the steps and still facing the error, please try to restart your devices and try again.
Thank you. I had not understood the difference between the IP address port and the pairing port, and that they are different!
