I have created Author Certificate through Galaxy Watch Studio V2.0.0. However, there is an issue that I cannot import the Author Certificate via Galaxy Watch Studio Converter V1.0.5. Please refer to the below; Is there anyone who can help me to sort this problem? Just in case, my laptop is MacOS Monterey 12.6.
I am afraid to say that I used the same Author Certificate that I used when I create the .tpk file. As you can see the above screen capture, even though I couldn’t try to upload any *.tpk file as I must upload Author Certificate first. Are you sure this is my issue?
If you can’t browse to find the .p12 there is an issue.
Can you uninstall the Galaxy Watch Studio Creator tool
install the last version v1.0.5
If it still doesn’t let you browse
What version of Java do you have and what version of Windows.
Sorry- I guess I make you confused. I can click browse button only for “Import Author Certificate”, however, it keeps showing the above screen capture message when I try to open author.p12. I used the same Author Certificate (author.p12) that I used to create the .tpk file. Additionally, I reinstalled Galaxy Watch Studio Converter V1.0.5 several times already.
Anyway, my system details are as below;
OS: Mac OS Monterey 12.6.
Java: jdk- 13.0.2 (x64). FYI- This version was in the GWS_BigSur which I downloaded it from the link that you provided before. Just in case, see the below;
When I first open Galaxy Watch Studio Converter
I get a dialog about not all can be converted.
I then click on browse for the author certificate and select the author.p12 file
It pops for password and I enter it and it imports the author.p12 file
