Fonts Cut Off
@Peter
Previously submitted request Dark UI or Custom WFS Theme. All pure white UI BG is overpowering content colors and causing eye strain.
This has been resolved for over a year I think the 1.2.x release of WFS
cache the AOD check so it does not have to run it each time we build unless AOD is changed
They haven’t removed it but they have greatly decreased the time it takes especially for run on device.
user/developer set variables like has Facer / Include a variable with a TAG to be designated by the designer
I know
Styles limit is too low allow more than 5 styles Inverse progress bar.
I think this is going to be a Play Store size restriction issue.
The ability to add Weather
I know and you know licensing issue
Move the timeline / conditions view to bottom like GWS. [SC_PER]
They are on the right column now, Probably a better location than bottom for most people.
Ron
Samsung Developer Relations
@Peter styles limit is 10 now.
Or is this talking about colors?
Thanks for feedback Ron, I know…
I was talking mainly about the fonts
Hi all! Please tell me how to correct the font height offset? Using what program? Or in some other way.
… p.s. Somehow I fixed the font I needed. I tried it with another one that was cut off in the front, and it also seemed to work out. I was only able to test it on GW4.
I had to update my watch faces by putting a space in front of data fields because of this issue and I have raised an issue with Samsung (#47943). For complications, where insertion of a leading space is not possible, I used the 'Sync to Device" font setting - and this displays correctly without the need for a leading space.
Thanks. That’s good to know we have another option. I resolve it by choosing another font. I just hope in the next version, WFS handles fonts better.
I have same issue font cuts in square emulator.
Circle emulator with api 30 is fine no cuts.
You can check my project
S copy.zip (3.9 MB)
If it not on complications then just give space inside of your text field. For example: space[HOUR_1_12]space
U designing for a square watch?
@Knightwing yes I’m designing for square watch. Is there any problem Samsung watch face or play console will not support etc?
Think its because of resolution of the watch u testing?. Like under suggest add spaces.
