Hi all
Is it possible to move the hour hand or battery hand move horizontally form left to right instead of rotation .
Thanks
JIM
Hi all
Thanks
JIM
I don’t understand why you need this. But I guess you need to use animation.
Hi WBRO,
I would load hour hand as image into watch face and make 11 or 23 copies (depends if you want to use 12 hour or 24 hour format). Than use tags in opacity window.
Maybe there is simpler way…
For battery its almost the same but different tag - (([bl]==3)?1:0)*100
Thanks , it help me a lot
