Hello forum!
I used to set up a few nice watch faces for my Moto360. I know it’s a bit older, but using ADB you can update the google play services and most things still work. It runs on Android 6.0.1./Android Wear 1.4.0.
The app I previously used is called “Watchmaker”, but with each update the problems pile up and I want to get rid of it and rebuild my faces in an independent way, so I can just install them on my watch, either by installing the face as apk via ADB, or via the phone with the WearOS app.
I have already created a simple analog watchface and built the apk. I tried to install the apk via adb, but it fails with [install_failed_older_sdk]. As there are no build options whatsoever I was wondering if it is possible to configure WFS to use the appropriate SDK level (should be 23 for 6.0.1) for building the apk.
I know it probably breaks some of the features, but we’re not even talking about features yet, just about plain functionality of the build.
