The seller office along with GWD need to implement IAP or TRY AND BUY allowing
smooth testing and a uncomplicated and easy layout for uploading, for testing, and ease of use for customers.
There are two problems,
Once you download you can not download the same trial version over; to ensure someone cannot just keep downloading a watch face freely over and over.
There seems to be an issue if someone has a download problem with IAP they can’t use IAP again on the same product because the cache thinks they have it already. They need to clear the cache.
The second problem is that for 99% of the Galaxy Store and Play Store users they are accustomed to In-App-Purchases to be additional features and so on that do not time limit the product. I believe this should be a Try and Buy listing not In App Purchase in the Galaxy Store.
We now have a Seller Portal Forum and I suggest you post this same issue there. I suggest you post this thread in the Seller Portal forum and I will try to get someone from the Seller Portal to respond.
Ron
Samsung Developer Program
First off , this is not about the customer trying to take advantage of the IAP feature.
Secondly IAP IS PART OF GWD defunct and redundant but still part of it.
A tool which effectively used can increase sales for all parties concerned.
Yes, I accept it should be “try and buy” , which I have mentioned in the earlier post.
But the simple point of it is, GWD and the seller Portal are connected and as such should be a topic of discussion on both the forums
Hi Malcolm,
My point is that this is not a bug or error in GWD. GWD implements In App Purchase / Try and Buy just fine. This is a Galaxy Store issue and Samsung Developer Program is trying to work with the store to fix this.
Ron
