Impossible to connect GW6 to watch face studio 1.5.7
Below is the copy/pasted content from the PDF that thathasarathkumar provided.
Thank you thathasarathkumar for this information.
Your watch and Laptop should be connect with same wifi
Step 1 : After clicking on “Run on Device”,
“Connected Devices” dialog box will open then click on “+” icon.
Step 2 : I hope you all know how to enable “Developer Options”:roll_eyes:
In Developer options enable “ADB debugging and Wireless debugging ”.
Step 3 : Scroll down in “Wireless debugging”.
You will see an IP address 192.166.143.1 and port 00123 enter those in respective boxes, after that click on Pair new device .
Step 4 : Here you get Pairing code 005632 and new port number 12345.
Enter those in respective boxes and click OK
Click on the device shown
In your watch it will look like this after connecting
It will take some time to run
After Successful running it will look like this
That’s it :slight_smile:
My table completes the settings you specified. And correct. Such a problem occurred at the last step of the push process. need your help
It may be occured due to poor wifi signal or too many devices are connected to the same wifi
Try this: Turn-on Hotspot in your laptop and connect watch wifi to that Hotspot and repeat the same process as i mentioned in the PDF.
note: Ip address and port number changes if you change wifi network in watch.
If you are using a PC and ethernet cable for internet and there is no wifi option in your PC, then you need a Wifi dongle to do this.
The wifi connection to the computer is normal. WFS uses a Windows PC computer, which is a router WiFi network connected through a WiFi receiver and signal. Is it because of this reason?thank you for your help。
Unsure watch is on charger…and same bandwidth… battery saving cut wifi from watch agreesively
Thank you very much for everyone’s enthusiastic help. My problem is finally solved. Thank you all. By the way, I would like to share that this problem exists because of the wifi receiver used on my PC. Just connect the cable directly from the router to the PC.。。。。。。
You are very appreciated. Your thoughts guided me to solve the problem. The watch face can now be pushed successfully. thank you very much.
I have tried to find the app on the watch app store and I can not seem to find it in the app store since Watch Face Studio does not appear for me when I look it up.
Hi what app? It should just push and you should turn on debugger mode
For anyone running into this issue as I have and you are running windows what you have to do is start the “WLAN AutoConfig” service, for some reason Watch Face Studio runs “netsh wlan show interface” before opening ADB.. I had to use process monitor from sysinternals to see what was happening..
