I am developing a WF for myself. It’s complete EXCEPT for 2 things I’d like to add.
It’s analog WF. But I do have a digital one (SMALL), it’s set for UTC. I’d like to be able to change the time zone on the fly if needed.
Before creating my own, I used Pro Analog. Under the battery status is … WEATHER. Like the rest of the world, I would LOVE to have it available too. Anyone know what Pro Analog is written with? I’d switch.
Assistance in making time zone a user setting?
Assistance in adding weather?
You to use World Clock complication for that I believe it is Large Box complication Slot
Pro Analog is written in a layer lower than WFS and has access to Samsung Weather app. For Weather in WFS the only option is by using a complication Again I think Large Box has several options for complications you might find one that is right for you.
For weather you could use Developer tools and license a Weather API hopefully you can select the Weather Complication that you shows what you want.
You could try a crude workaround, make 12 images of the extra hour hand each turned to respective angle and add them as styles so you can pick the one with desired difference
CANNOT connect to the watch any more.
Yea that is complicated now really complicated
do the run on device as before add the IP address and a box comes up that needs data filled in
Developer Options same tap on software version to enable
ADB Debugging
Wireless Debugging
once it connects takes a few seconds
click on the connection and write down the IP address and Port
Now Click on Pair new device just a bit below this
write down the Pairing Number
and the port below the paring number it is different
Put that information into the dialog box
Now a tricky part WFS may still say no device found DO NOT START A NEW SEARCH
give it a while you may have to ok it on your watch but I don’t think I did
after a while it connects and you can run on device.
Step count no longer displayed.
What version of WFS are you using? if it is 1.3.13 you need to update to 1.5.7 or at least 1.4.20
Weather (lg) box complication needs font tweaks.
This is a know issue a lot of the complications seem to mix Title and Text up but Weather has other issues.
If this is a complication go to Samsung Health scroll to the end to settings scroll then again almost to the end and allow share with devices and services and add Heath platform.
But my next event/calender complication couldnt display at first after update to wear os 4. To fixed it i run on device again. Also hr complication instead of a heart shape displayed the word heatrate. (Re creating the complication and run on device again fixed it)
WFS 1.4.20 and 1.5.7 (better option the beta is for the plugin not the Watch Face tool) It uses what the user has set in Samsung or Google Health app. The default for those is 6,000.
Are you using your own progress bar or are you using the Circle slot and selecting Ranged Value type?
The [SC] tag works fine for me and for 3rd party watch faces that I have purchased.
I also am old with poor eyesight and fat fingers so don’t always get it the first time.
Under sounds settings there is one for debugging connected or something like that. I’ve found that works even after WFS says not connected devices it chimes a half minute later and sure enough it pops up. Trying to connect again and again just restarts the process so wait a while.
