I just changed the type to text. That seems to work just fine.
While im in wireless debugging and allowed that. I see the ip and the port, but when i press pairing new device the port changes. I dont know what port i shall use. Also i cant find the pairing port what is that?
@lgk10usb please zip the files up and post directly if you want to share hereā¦external link make it unsafe.
Can you please guide me how did you install it with cmd.exe i dont understand codinf language at all. Can you tell me step my step procedure for that.
Hello,
Welcome to this forum.
You can download the Watch Face Studio from here. You may check this blog also. Could you please share which type of issues are you facing when you try to deploy using Run on device?
To use the Watch Face Studio, you donāt need coding language.
Thank you.
Hi Ron,
Iām having a heck of time. I do get watch connected and it will upload face one time. If I try again in a few minutes, it wonāt update. The only solution so far is to turn off ADB, restart watch face studio and go through the process again. USUALLY it works again for the first time but only once. Going crazy with this. Any ideas?
The Watches are set to automatically switch off WiFi to save power . When it switches on again the Last part of the Port address is changed and you have to Pair it again . there is a setting in the Developer options in your Watch that you can set . Disable Automatic WiFi . So that is ADB debugging and Wireless debugging on . I find I have to Pair up quite often . When the Wireless debugging switch is blue on the Watch I start the Run on Device in WFS .
If the 12 part of the port address is changing you need to change the setting on your modem to hold the port number . 192.164.0.12.34567
BTW Ron has retired .
Hi Russel - I did what you suggested. The WIfi address doesnāt change anymore but still same problem. Thank you though for trying
You have read through this Blog that @Boshra posted ?
What PC are you using ? Do you switch off the Bluetooth connection ? Your Watch is selected in Galaxy Wearable on your phone ?
Hello. I have an issue, I manage to connect watch 5pro to pc, but error window (connection unstable) apears when trying to send wf. Tried resetting watch, and wf studio, nothing helps.
@ivoda.stijovic Have you followed carefully the Instructions in the Link above . I have a GW5 PRO . I have no issues Running the Face from WFS on my Watch . Where do you think you are getting stuck . Do you think you could send a Screenshot.
@ russellcresser Iām not sure what can b the problem, I always connect to watch, but when try to upload wf that window appears. I did everything from earlier posts, really donāt have no clue.
I wonder which Nation you are in . Have you been able to Run Faces on your watch Previously . Check out the solution at the end of this topic .
I live in Serbia. So, the cable should solve the problem⦠Iāll try itā¦
@ivoda.stijovic It is worth a Try .
@russellcresser No. That didnāt help. I never undestand why simple things can b so difficult, itās file transfer, nothing else⦠Thanx for trying to help!
Sorry . I am no expert . I am surprised none have joined in . If the standard transfer does not work it is very Difficult . Mine is not Flawless but I get there in the end with Reboots of Laptop and Watch . The WiFi connection and Paring has to be quite fresh . Once a connection is established I get successfully transfers one after the other .
Put watch in charger. Check if you are on same band. Alternative use command line prompt to pairā¦there a guide that show u how to use debug command line.
I did it already, I connect to watch, but error when trying to transfer wf to watch.
