Which methods? U used…comand line?
Wifi or lan ?
Would suggest reading more on adb.
Are you able to locate the complied file?
From chatgpt…now days can used chatgpt to help:)
Wifi or lan ?
I connect via wifi. When press run on device,pc sees my watch and connects to it, but after that it’s loading and loading and loading and the window run on device failed appears.
U might be having a network issues…like i say try adb instead of run on device.
Check your watch if its still state in paired or disconnected
Try ./adb if adb is in that folder
It might be .\tools\window\adb.exe
…or…
%LOCALAPPDATA%\Programs\WatchFaceStudio\tools\window\adb.exe
Android Studio also installs it (elsewhere).
I’m giving up, I’m not an expert, but also not someone who sees pc for the first time. I really don’t know what to do. Thanx everyone for being patient.
Now use connect to connect to watch.
Please read guide. Anyway is your Bluetooth on the watch on? U can turn it off so that watch to switch from wifi to Bluetooth accidentally. It happens sometimes
Bt is turned off, it didn’t help. I’ve read all other posts earlier, I’ve tried everything, trust me.
So when you see this pop up is the Port number the same each time . Do you click on the Watch Flag . If it does not pop up do you type the paring numbers in from your watch ?
Your example nvr use connect
You have success pair but not connected…u say u read but
Plus did u try my transfer by adb?
Try this
I published the apk and then installed it but it doesn’t show up on my phone or watch? I have an ultra.
First turn off bt on watch, than on pc from wfs folder connect to watch via adb, than start wfs, click on run on device wfs doesn’t see my watch, connect wfs to watch manually, error that I posted earlier. Also tried with cable earlier, no help. Never mind, I give up, this is ridicolous.
Is its under downloads in the app / watch if install is successful
You forgot to mention if on the watch is charging?
And also does your watch show your pc is connected or it being disconnected already
2 things can happen.
(Are you on mesh? Or single router?)
(Harder to solve)
P.s watch something like this
Or
Blank? After run on device?
I was able to figure out the connection. However, the installs don’t show up even when it says that the watch face was installed.
I did figure out the connection issue so I am installing like that now seems to consistently work.
By the way, I would like to code my own faces. Any good guides how to do it on android studio or other software?
I haven’t played much with watchface studio but seems a bit limited? I am trying to add some tap actions but there are none that would work for what I want to do, primarily change colors in realtime.
Thanks
