Run On Device - problem
Short answer: yes, it can be done in Android Studio.
Bear in mind that WFF is the only watchface system used on Wear OS 5, so older code-based approaches are effectively deprecated.
Before jumping into Android Studio, ensure that the limitations you’re seeing are due to WFS rather than WFF. Check out the WFF XML doco.
If you use Android Studio (and I am), its role is basically just XML text editor (with no WFF-specific assistance), command line access for building and installing, and Android Emulator for testing.
If mesh even at 1 m still can hop. Sometimes
Hz also 2.5 or 5gz have to be same.
As i have help many users here. All solved and they realised is not the wfs but their settings of wifi, pc, etc.
Does your pc have firewall?
Wifi signal strength? For both watch…is wifi still on for both
Alternatively try a older version of wfs 1
6.9
My watch is 5pro no issues so far
