Run On Device - problem
Its default function on the watch…so if u take to long to connect / pair the watch think u not using wifi and it cut off.
Only way to disable that is watch on the charger
Also lan to have similar signal your watch should be 5gz
It not only wifi signal somethings like “noise” interference. Bandwidth the pc and watch are on. Router not stable etc
And you did follow the adb command…
Pair
Connect
Install
If you’re still having trouble after following the above tips, watch my video which shows (what I think is) a foolproof method of getting your watch face onto your watch… https://www.youtube.com/watch?v=9zFB2EDr3xk
Good luck,
Rob
