Since the last update of the watch software my watch face is showing speed.
Unfortunately the speed it shows is in multiples of 3.6 km/h. So it shows 0 or 3.6 or 7.2 or 10.8 or …
I tried to change the display type from %d km/h in %f km/h.
After the project is saved and then reloaded it shows %d km/h instead of %f km/h.
So i guess %f km/h is apparently not right.
How can I fix this?
This was a known bug in Tizen 4.0.0.4 and was to have been fixed in Tizen 4.0.0.7 can you verify that this is in Tizen 4.0.0.7 version? If so I think you will need to open a tech support request and give them all your Tizen version, model and other software information.
Ron
Samsung Developer Program
I have the same problem on the gear s3 version 4.0.0.4.
How can I install version 4.0.0.7 ?
It is not automatically proposed to me.
Thank you
You probably will need to contact your service provider. I had the same issue with my service provider not pushing the update out. From the about watch give them your watch’s model number, version serial number and in the About Watch - Device information the current software version
Ron
