Watch hand as button - problems
I’m using a seconds hand with sweep motion, I’ve set it as a button and added 10 images. Every image is 360x360. But when I run it on the device, the tap action is sometimes registered sometimes not. For example, it will swap images 3 times in a row and then stop working, then after 10 taps it will swap a couple then nothing for 4 taps etc. Totally random, there is no pattern to explain it.
Anyone had this problem? Any ideas on how to solve it or what may be causing it?
As I mention, it’s just a simple seconds hand, the movement is CCW and motion is sweep. Set as a button, more images added. In GWD works perfectly, on device works a little bit then doesn’t then works etc.
I think it is a bug in Tizen 4.0.0.7 and it doesn’t do it with normal movement only sweep.
Let me know if that isn’t it or file a bug report
Ron
Samsung Developer Program
Oh, shoot… Thanks Ron, I hope this is already reported?
Since I’m using sweep movement, it would appear that this is the cause.
