Is there a way to get tutorials posted here edited? Here’s the tutorial I used to learn how to send my WFS designs to my watch. It says that you must turn off Bluetooth prior to setting up for Run on Device. It’s basically the first step.
I am quite certain @Gondwana above has some influence . Please understamd I can only relay my personal experiances in the hope that I might help . It is not for me to rewrite a piece of Documentstion that is a bit old now . I would guess there have been more than 6 WFS updates since that Document was posted .
I find the document misleading becaise it shows the first time Run . It does nor show what should be seen on another Run or a Failed one . Like a lot of technical docunentation it is not made by a user and we have to learm all the Debugging for ourselfes .
Alas, I have no influence with Samsung. It may be possible to get the issue addressed by submitting a bug report. I don’t have a link to that site, but someone else will.
@KE3JU are you using a windows machine?
Yes, Windows 10 and 11. But that shouldn’t matter. The fact that my GW 6 Classic stays connected all day long, and my Ultra needs to be reconnected after every sync, tells me, it’s not the OS. I feel like the Ultra just doesn’t like to stay on the WiFi. You’d think after an ADB connection, the watch would want to stay on the WiFi to satisfy the connection. I wish they would enable Bluetooth Debugging. It would simple things.
