Hi,
I have installed WatchFaceStudio 1.3.13, and I have updated my Google play apps.
now in Android studio i have created two virtual devices, one smartphone and one smartwatch.
Pixel 3A API 31, and Wear OS API 28.
In this way I can test my companion app, which works.
But when smartwatch opens google play to install watch face, it says: that the application is not compatible…
I don’t understand how it is not compatible ?
I have also tried with Wear OS API 30, and again I receive msg: the application is not compatible.
But when I directly install watch face without Google play, then it works normally…
how to correct that problem?
From google play, it says: 59 supported device models
how much your watch face support devices ?
what means: Not opted in  ?
I hope you can help me
Thank you
              Hi. You most probably forgot to opt-in for Wear OS form factor in the Play Console.
Go into Setup > Advanced settings > Form Factors
and opt-in for Wear OS. Your app then need to be re-verified again by Google.
              Hi,
how to do this ?
when I go here: Setup > Advanced settings > Form Factors
did you do the same ?
as I dont have testers
              You don’t need testers. Just add your own email address
              Hi,
ok. I have done done that, please see screenshoots:
msg:
Under Releases overview:
Form factors:
Device catalog:
but for some unknown reason when i click on View on Google Play link, I get this:
although it says:
Available on Google Play
Full rollout
I don’t understand why that is? was there a mistake, or do I have to do something else?
Thank you again
              One thing more, I found this msg:
I dont know what this means ?
Thank you
              You need to publish wear os aps under dedicated ‘Wear OS only’ track
              Hi,
I just want to say, that everything is working
thank you amoledwatchfaces
