I created a watch face in GalaxyWatchStudio, however I can’t connect my PC (neither GWS nor Tizen Studio device manager) to my Active 2 watch. Using bluetooth (option 2 in tutorial) is not an option as I have an iPhone. I can only “Run on Device” over WiFi. I checked the suggestions in why can’t I connect to my device FAQ. Based on that I’m expecting problems are caused by either of the following two things:
- RSA encryption key not being accepted on the watch. Note; I’m not sure if I ever accepter or denied a RSA encryption key. For sure, since I started working with GWS, i’ve never seen it pop-up. If this is the expected issue; how do I make sure the pop-up to accept the encryption key will appear? Several reboots of both PC and watch didn’t resolve this.
- Firewall blocking connection of the Laptop to the Watch. I can ping the IP of the watch, but simply can’t connect, neither by GWS, nor by Tizen Studio Device Manager. However, even turning the PC firewall off, doesn’t resolve the connection problems
What I did thusfar:
- Went through the steps noted in this topic on how to set up watch and tizen studio device manager., so now Watch Wifi is always on, Bluetooth is Off, Both devices are connected over the same 2.4Ghz WiFi, Developer mode is on (pressed ‘software’ 5 times).
- I managed to get untill step 8 of the Tizen Studio steps. However, when turning “ON” the connection to the watch, I get the error “error: Failed to connect to remote target: :26101” (Same error as in update2 here
In the linked topic, however, it turned out the “Developer mode” was still “off”, which is “on” for me. I have no other idea than the two suggestions I put above. I hope you can help me out managing to set-up the connection. Thanks in advance.
